07-25-2015 03:57 PM
I cannot figure out why the DAQ I/O indicator called AIN task reference id out, is always blank. After the attached bit of code, and somewhere else in my huge body of code, I call DAQmx Read.vi, and feed value of this AIN task reference id out, into it. I actually get the data back from the board. While I'm glad I get the data from the board, I cannot figure out why the id is blank.
Once, while the hardware was running continuously for weeks, analog input data stopped coming back to my software ... that's another story. I thought if I could track the task reference id, it would be a good start.
Thanks ahead of time for any help.
07-26-2015 06:23 AM
Task ID controls / indicators do not have a visual representation, largely because there's nothing for the user to sensibly edit. You can't just type in a new ID number and have it mean anything.
If you want to see the number, put a PROBE on the wire going to the indicator. You can see a number there (0 = no task).
Consider adding your case to this idea and voting for it.
