Why is there so much noise on the discrete lines of my PXI-7831-R?
Hi  ritch_by_nature
I took a look at your thread and found no references to the sampling rate used and the frequency of the signal you are acquiring. Since the Gibbs phenomenon is related with the # of harmonics available to reconstruct the signal, maybe setting a higher sampling rate could help to reduce that effect.
Have you considered doing that?
WenR
Message 11 of 11
(223 Views)
