Why my custom control change the sizes, when i open it on different computers ?
I create a  custom control, and when i  open it on other computer it changes size
Message 1 of 8
(3,561 Views)
could be the display settings are different between the 2 computers. I wasnt able to open the ctrl as i only have lv2010
hope it helps
TD
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 2 of 8
(3,554 Views)
I create a control, then use it in my VI. On my computer it has a normal size. When I open it on other computer, it changes the size, and then on my computer it has the bad size to (The size grows up).
Message 3 of 8
(3,544 Views)
Do you have the front panel on you program resize to fit the screen?
Tim
GHSP
Message 4 of 8
(3,535 Views)
No, I  haven't  resize to fit the screen.
Message 5 of 8
(3,526 Views)
maybe doing it automatically
TD
Message 6 of 8
(3,524 Views)
Accepted by topic author Manushak
Try to:
- show boolean text
- use a specific font for the boolean text (e.g. Tahoma, but NOT system, application or dialog font)
- hide boolean text
- save the .ctl
In my experience it's the text boxes causing an object to resize on different systems since the application/system/dialog fonts are different.
Message 7 of 8
(3,515 Views)
@dan_u wrote:
Try to:
- show boolean text
- hide boolean text
- save the .ctl
Along these lines.... If you open your control in the advaced customize window you will see that your label is not with the rest of the button. See if moving that inside the button helps:
Tim
GHSP
Message 8 of 8
(3,512 Views)
