Why some controls resizes in an Executable?
i've created an 'exe' in which some front panel controls reduces size (differ from LV 8.5.1 development sysetm). especially all with floatingpoint datatypes.
what could be the reason? can i avoid this problem?
please reply with ur suggestions.
thanks
RENN
Kudos always welcome for helpful posts 🙂
(4,316 Views)
Check in File -> VI properties -> Select window size and see if 'Scale all objects on front panel as window resizes'.
(4,301 Views)
Does this happend on both your target and development PC, or only at the target PC? If the tip from bo200008 do not help, it could be the font rescaling problem. I have written about it here
http://forums.ni.com/ni/board/message?board.id=170&thread.id=384019&view=by_date_descending&page=1
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,290 Views)
Better link so the thread can be read in chronological order.  http://forums.ni.com/ni/board/message?board.id=170&thread.id=384019&view=by_date_ascending&page=1
(4,267 Views)
I guess you are correct, This is not jeopardySmiley Very Happy
(4,259 Views)
this problem happens on my development PC. Why does it change size on the same PC?
(4,201 Views)
