Why the 3rd shortcut menu doesn't take effect?Thanks.
(1,700 Views)
Accepted by topic author LittleBigPig
Your Item Tags are "C" and "F", not "True" and "False".
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(1,683 Views)
Paolo, Item Tag only true or false? How to make it used like Enum if I have 3 or more items?Thanks
(1,645 Views)
Item Tags are strings. If you need to manage more than two options, you can add a case to the Case Structure accordingly (right-click, then choose Add Case After or Add Case Before, then edit the new case value). Of course, when you wire a boolean to the Case Structure input, like in (2), you can have no more than two cases.
Paolo
(1,607 Views)
Menu item tags are less than user-friendly because they don't auto-update.  This can be a pain, but if you create your menu at runtime, you could use globals for your tags.  It's more work than using the menu editor, but it's more flexible.
Actually I guess this wouldn't work completely, as your cases need manual updating.
Bill
CLD
(Mid-Level minion.)
(1,599 Views)
