Why the Vi called in the main Vi automaticly run?
Hi,everyone, I am just using Labview to build a DAQ application, and I have build some VI subapplications.
Just as some one mentioned, I aslo build a main operate board with several buttons. When you press any
button, it trigger associated subVI.
 I have just referenced some examples to achieve that, such as "Dialog  Box Demo.vi", "Login dialog,vi" .
But have anybody find that when the associated subVI is opened while you try to run the main VI, the associated
subVI automaticly run.
Open both "Dialog Box Demo.vi" and its subVI "Dialog Box.vi", then run "Dialog Box Demo,vi", so, what can you do?
(2,916 Views)
Addition: edition of labview I used is7.1
(2,913 Views)
if I understand you right, the subvi is not actually running (look at the stop button, until it is running, you can't press it, but you also can't press run).  If you run a higher level VI, it takes control of the running of the lower level VIs and prevents you from running it (because if a lower level VI is already running, the top level can not start)
(2,905 Views)
yeah, How foolish I am, Thank you!
(2,898 Views)
If a SubVI is open (because you where editing it) and is set to Modal
(because it is a dialog), the VI will appear to be running if you start the
main VI. If it's enabled, you can simply close the panel.
Wiebe.
(2,873 Views)
