Why the excel file can't be created by the vi after I build it.
Dear All,
        My vi can work well and creat the excel file before being built.
        But after I build it, the excel file can't be build and no error message is displayed.
        During the process of building, I have checked "enable activeX server".
        And the log file is:
Microsoft (R) Type Library Generator  Version 2.20.4048
Copyright (c) Microsoft Corp. 1993-1995.  All rights reserved.
Successfully generated type library 'pal2com.tlb'.
        I don't know why.
        Please help me and give me a suggestion.
       Thank you.
Hugo
(3,253 Views)
How do you generate the path of the excel file you create ?
If you use the "current vi's path" + one "strip path" then it is normal that when you run the exe it doesn't work.
When running as an exe (application.exe for instance) the vi's path is not C:\name.vi but C:\application.exe\name.vi
To make it work both in edit mode and exe, you can plave a "strip path" in a while loop and get oout of the loop only if the path points to a folder 😉
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,248 Views)
Thank you for your reply.
Yes, you are right. I have used the "current vi's path" + one "strip path" .
But I can't understand "you can place a "strip path" in a while loop and get out of the loop only if the path points to a folder"
How can I do that?
Thank you.
The vi is attached.
Thanks.
Hugo
(3,229 Views)
Here's another way. It uses the application property App.Kind wired to a case structure. In the Run Time System case, the extra strip path is placed.
Message Edited by Dennis Knutson on 12-11-2006 09:44 PM
(3,218 Views)
As Dennis showed, there are different way to get the path of the containning folder that will work also in exe.
Here is an illustration of what I meant :
Message Edité par TiTou le 12-12-2006 07:45 AM
Epictetus
Antoine Chalons
(3,206 Views)
oh,Thank you very much:)
Hugo
(3,191 Views)
