06-10-2003 12:09 PM
06-13-2003 10:15 AM
02-02-2009 04:31 PM
Hello Nick;
I'm encoutering the same situation. I'm finding a RS232 propagation delay of 20 ms (with MAX Tx FIFO size =64 Rx FIFO size=64 on both Tx -COM4 and Rx-COM5).
I can not explain this 20 ms. To make things worse, sometimes I'm getting 0.0001 ms (or less). I'm sending a 15 bytes packet that apparently takes 20 ms to trave !!!.
Please refer to my attachments TXside.vi and RXside.vi.
Please refer to the folllowing link for my exact situation and what is my problem:
http://forums.ni.com/ni/board/message?board.id=170&message.id=54343&query.id=97644#M54343
I re-attach the code here. My results with this code are:.
1) 19.9 ms -20 ms when using 64 bytes both Tx and RX FIFOs at both ports. Rarely, I'm getting also 0.0001 ms (or less).
2) As described in "Loopback_Test_from_COM4_to_COM5_Using_Different_SerialFIFOconditions.txt"
Thank you very much for your help;
KizKas.
02-03-2009 09:23 AM - edited 02-03-2009 09:24 AM
You are following up on a six-year old thread.
Plus, Nick hasn't logged in since 2003, so he's not likely to even see your message. Your best bet is to start a new thread and reference this as one that you saw as having a similar problem.
Nevermind, I see that you've started one.
