Why the frequence I measured is double of my input signal‘s frequency range?
I build a vi to generate a sweep sine signal,the frequency range is 0—50Hz,but when I measure it,I find that the frequency range is 0—100Hz。
I check over it and stil cannot find the problem. PLEASE help me out!!!Smiley Sad
The picture below shows my program.
Also, I attach my vi here and hope somebody can give me some help.
(5,647 Views)
Take a look at your generated sweep:
Right at the end, for the highest frequency, there are 10 points per period. That's 10 x 0.001 seconds = 0.01s = 100Hz.
Therefore your sweep is generating a 0Hz to 100Hz sine wave, and not 0-50Hz as you think.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(5,627 Views)
Accepted by topic author Lancelot3718
Perhaps consider the Chirp Pattern function:
(5,622 Views)
YEAH~~,Thank you very much. Your anwser helps me a lot.
But I still cannot find the mistakes in my program, can you tell me where is the problem?Heart
(5,567 Views)
I'll admit I'm not sure where the issue is. Your final value for frequency into the SinePtbyPt function is 50, so you're not asking for 100Hz. Therefore, it must be something about the way in which the Sine function is called, and the phase relationship as the frequency increases. You might be seeing a phase sweep phenomenon that is artificially adjusting your sine frequency as you time progress. Maybe someone else with more experience using this function will comment.
BTW, you don't need the timed loop for this unless you are specifically intending to display the data on the chart in real time. You can just use a normal while loop.
(5,538 Views)
Thank you, as you guess, this Vi will be used in a real time control system. Smiley LOL
Thoric 已写:
(5,525 Views)
