Why the front panel is locked (no scrolls) in Set Tabbing Order in Labview 8.20?
When I am using the Set Tabbing Order... in Labview 8.20, I cannot scroll the front panel as what I used to do in the older versions of Labview. How can I unlock it? Thanks.
(3,084 Views)
I see what appears to be a cosmetic bug that could be confusing.
In LV 8.2 it LOOKS like the scroll bar is disbaled but it still worked for me.
This is different from LV 7.1
Did you try to drag the scroll bar and it did not work?
Ben
Message Edited by Ben on 02-08-2007 07:47 AM
(3,072 Views)
Thanks Ben.
After reading your response. I double checked it and found that if the option "Show vertical/horizontal scroll bar" is unchecked in the "Customize Window Appearance", then it is locked in Set Tabbing Order.  This does not happen in older LabVIEWs.
Thanks again.
Cuong
(3,055 Views)
