Why the time differece between a timed loop will always be 32ms even I have set the period to be 10ms??
The timing is guaranteed only if:
- you're running a real-time operating system (Windows definitely is not)
- the code into the loop can be executed within the specified time
It seems that your computer has a slow access to the HD. How much RAM? (XP pro?).
Still, I would expect some more jitter about this magic number 32.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 11 of 14
(759 Views)
can you repeat your test without writing to file?
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 12 of 14
(755 Views)
I too get 10ms steps.
Try setting the step to say 50ms. Do you get 50ms or is it still 32ms!! ?
Rgds,
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
Message 13 of 14
(743 Views)
If you are curious about your hard drive write speed, try this website.
http://www.hdtune.com/
I found this program while I was installing solid state hard drives on 40 computers at work this week. Don't ask why I had to find it.Smiley Tongue
Message 14 of 14
(741 Views)
