12-08-2004 02:10 PM
12-08-2004 02:19 PM
I appreciate your efforts. But look at the output of the VALUE property node. I show a new buffer being created there.
It's true you're no longer doing it at the WRITE file, but you've added a new buffer at the property node. So the same problem exists, I think.
12-08-2004 02:24 PM
12-08-2004 02:29 PM
12-08-2004 02:58 PM
12-08-2004 03:02 PM
In my case, that is immaterial. The create / write / close will be a single operation.
My data will contain a huge array, and THAT will be empty, but the structure will still contain 250k of clusters and stuff. Maybe that's the best I can do.
FWIW, I created a constant from your latest typedef, and used that as the DATALOG TYPE into NEW FILE. It still created a new buffer at WRITE FILE. But if I disconnect the constant from the TYPEDEF, it does not.
12-08-2004 03:03 PM
This has been my experience as well. Getting even the value via a property node is VERY expensive, in terms of time, compared to a wire to the terminal.
12-08-2004 03:21 PM
12-08-2004 03:55 PM
12-08-2004 04:02 PM
