Why timestamp can not show time between 0:0:0 JAN 1, 1970 to 8:0:0 Jan 1, 1970?
Message 1 of 9
(3,745 Views)
Hi Qizhen,
what do you mean?
Mike
Message Edited by MikeS81 on 04-25-2008 09:46 AM
Message 2 of 9
(3,741 Views)
Create a new timestamp constant on block diagram.  Then try to input 1:0:0 JAN 1, 1970 on it.  Click mouse on other place, the time will automatically changed into 7:59:59.000  1970-1-1
Message 3 of 9
(3,731 Views)
帖子被Qizhen在04-25-2008 04:53 PM时编辑过了
Message 4 of 9
(3,730 Views)
Hi Qizhin,
for me it worked, though I admit it was a bit tricky to set the time with the up-down keys. I attached a VI with the Timestamp preset to 00:00:00,000, 1.1.1970 and countig the seconds up to 8 o'clock.
greets, Dave
Message Edited by daveTW on 04-25-2008 09:53 AM
Greets, Dave
Message 5 of 9
(3,729 Views)
Thank you,
This is interesting,  it works with the up-down keys, but can't be changed directlly by inputting a number.
帖子被Qizhen在04-25-2008 04:58 PM时编辑过了
Message 6 of 9
(3,723 Views)
Hi Qizhen,
for me it works, too, also with insert it directly.
Mike
Message Edited by MikeS81 on 04-25-2008 10:12 AM
Message 7 of 9
(3,716 Views)
Qizhen,
what is your timezone of the timestamp indicator?
Is it a valid time?
Ton
My LabVIEW Ideas
Message 8 of 9
(3,704 Views)
My timezoon is GMT+8, Beijing time.  This could be the reason.
And I uses LabVIEW 8.5
Message 9 of 9
(3,693 Views)
