Why wont my system find a pattern after upgrading to LabVIEW 8.6 and Vision Assistant 8.6
After upgrading my system, the IMAQ Match Pattern 2.vi doesn't seem to operate. Any ideas I might try? I have already completed a complete uninstall and reinstalled Labview and the vision development module and still no go. My other system runs this vi just fine.
(3,264 Views)
Can you describe what is not working? I tried your example and it worked just fine for me. In the Matches cluster it finds my template and updates Posisiton/Bounding Box, etc. of my pattern.
Also, how are you creating your template?
Give my test image (NIOCRExample2.tif) and template (TEMPLATE_MatchPattern2.png) a try...
--Michelle
(3,235 Views)
I tried using your image and template to no avail. Still no pattern matches. Ni engineers are working on this problem now. Thanks for the try.
Rick
(3,216 Views)
Have you tried Vision Development Module 8.6.1 patch? Some issues were resolved in this patch, and it may correct any issues you're having (if you are still having any).
8.6.1 Patch
I know this patch specifically fixed some issues with pattern matching.
Hope this helps!
Cheers,
-Matt
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,103 Views)
Thanks, Yes I've tried that as well. I believe my computer is at fault somehow. I will be getting a new one shortly. Hopefully that will alleviate my problems.
(3,099 Views)
