Wi-Fi LED system
I am doing a project on Wi-Fi LED system using program from labview and arduino. It involves using data dashboard from iPad to remotely control the LED via a wireless router. I want to add another function, that once the iPad is connected to the router, the LED will turn on. Pls help.
(4,499 Views)
What have you done so far?  Attach your VI.  Where are you stuck?
(4,493 Views)
I have just finish trying out data dashboard, as well as web server. However, I want to know whether if LabVIEW is able to turn on the light once it detects the active connection between the data dashboard and the router.
(4,484 Views)
LabVIEW can't turn turn on an LED (and I assume you are talking a real hardware LED and not an LED indicator on the front panel.)  LabVIEW is software.  You need hardware like a data acquisition card to drive a real LED.  Then depending on what you use as your DAQ card, LabVIEW can communicate with that to turn on/off the LED.
(4,457 Views)
I am trying to link the arduino board and labview together via serial communication using the attached vi. However, I cannot seem to turn on the LED. please look at my program and advise me. Thanks.
(4,432 Views)
Your LabVIEW VI is taking the boolean value and typecasting it to a string and sending that out of the serial port.  So it will either send the value 0 if the boolean is false, or a 1 if the boolean is true.  I'm sure your LabVIEW code is working just fine in this aspect.  Note: this is not the character "0" or the character "1", but the binary/hexadecimal value of 0 and 1, which are both non-printable control codes in the ASCII table.
The question is, what does your Arduino expect?  What code do you have running on it?  How does it know to turn on a specific LED if you get the 1 at the serial port or turn if off if you get a 0?
(4,398 Views)
Hey,,s10114751 !!
After reading your entire stuff from the post I still have a question in my mind the can please elaborate what's the basic role of Arduino as if I'm a bit confused to answer your question and it would be great if you could tell me its role so that I could guide you perfectly.
(4,316 Views)
