WiFi monitoring with NI 9191
Hi everyone!
I'd like to monitor the WiFi signal strength of an ad-hoc network I create with the NI 9191 in my labview application.
Ive been trying to use the system information via the win32 API with no chance (not an expert in dll-s and so on). So I thought that there might be a more direct approach. Does anyone know about how can I access this information in the WiFi chassis itself? There must be a property node for that, right?
If not, has anyone done this before? Whats the best approach?
Thanks in advance.
(3,155 Views)
I'm not sure if this is what you want, but you can obtain "signal strength" (as in "Windows WifFi signal strength bars") using this command line spell:
netsh wlan show networks mode=bssid
You can parse the results to get the signal strength, see the attached example.
(3,130 Views)
Thanks for your answer.
Yeah, that's the first thing I tried. The problem with this solution is it doesnt update, unless I clicked the network flyout (Win10).
The networks are updated when a scan is completed by your WiFi card. The netsh command you are running does not request a scan, it only displays the cached results of the last scan. Opening the network flyout updates the results because the network flyout happens to request a scan when it first opens.
There is no netsh command to request a scan like this. You would have to write some code, leveraging either the Win32 WlanScan function (C# wrappers exist if you prefer that), or the WinRT ScanAsync function.
By the way, Im using LabView 2014 Smiley Sad
(3,118 Views)
