Wifi AP Throughput Test
I am doing a project about Wifi.
RF test have almost completed with IQflex,but for final test,I don't know how to do now.
Hope can get any suggestion.Thanks in advance.
I want to use two units and one computer to do it.
Computer send transmit packages command via telnet to one unit which is regarded as golden board.
Golden will transmit some packages with anta,DUT was set receive status.
After transmit finished,calculate spend time then get  xxMbps
I don't know this method if it can be achieved,hope your help.
note:chip is ralink 30xx
thanks
(3,885 Views)
Any ideas?
(3,875 Views)
did you get the working with labview, i am also try to do it soon. i have no idea how. if you did could you share. thanks
(3,553 Views)
For Wifi/wimax you need to consider a base station and a subscriber. Base station to subscriber is  DOWNLINK and the opposit if  UPLINK. or consider a client and a server. You need to send some data and use TCP write and Read...
(3,540 Views)
I am also need to do it the same like yours do you have any progress?
(3,445 Views)
