Will 2010 FRC labview (ver 8.6 ?) run in windows 7 64 bit Home premium ?
Will it run in windows 7 professional 64 bit ?
thanks
(4,336 Views)
Hi LVHelper,
Sorry I didn't catch this question sooner.
Unfortunately, I don't have the answer to your specific question regarding LabVIEW FRC. However, you may have already found that we have a separate, dedicated community for FRC questions. You can check it out here: ni.com/first
I suggest you submit your question to the FRC discussion forum, as they should be able to provide you with an answer.
Emilie
(2,231 Views)
I believe that it should work.  I have labview 2009 running on windows 7 x64 and had v8.6 running the 64bit RTM/Beta version of windows 7
CLAD, using LV2013SP1 + LV2015SP1+ LV2017 on Win7+cRIO
(2,231 Views)
Thanks for the help.
(2,231 Views)
