Will Runtime 2013 run 2009 applications?
I installed Runtime 2013(32 bit) and tried running a 2009(32 bit) application (double-clicked the app). It didn't work.
Are runtime engines not backward compatible?
Jeff
Jeffrey Bledsoe
Electrical Engineer
(3,131 Views)
Accepted by topic author MinerHokieRamp
No, you need to install the run time engine corresponding to the LabVIEW version used for the build. You can install multiple version and the executable will automatically use the right one.
In your case, you need to install two run time versions: 2013(32 bit) and 2009(32 bit)
(3,126 Views)
You do need to have the version of the LabVIEW runtime engine that matches the version of the exe application.  Sorry 😞
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,124 Views)
Thank you.
Jeffrey Bledsoe
Electrical Engineer
(3,120 Views)
Thank you.
Jeffrey Bledsoe
Electrical Engineer
(3,118 Views)
