Will labview 2020 also work as labwindows CVI 2020
Hi
  1. Will labview 2020 also work as labwindows CVI 2020
  2. Will labview 2020 (or labwindows CVI 2020 if supported) be able to save files in labview/labwindows 2010 format?
(1,221 Views)
LabVIEW and LabWindows/CVI are completely separate products. Have you studies the product pages yet?
(1,213 Views)
Maybe there is a language barrier. Can you explain what you mean by "work as". As currently written, it makes about as much sense as asking if a banana can "work as" a airplane :D)
LabVIEW 2020 can save VIs all the way down to LabVIEW 8 (using "save for previous"), but the success depends on the code. Some features (e.g. sets and maps) only exist in newer versions.
Labwindows is text based. No conversion needed.
(1,202 Views)
