Will my runtime application run on a foreign language OS
Will a runtime application developed in English Labview run on a PC with Korean Windows XP?
(2,402 Views)
Generally it is OK, however, if you use some system specific features (such as when you check to use local decimal points), you might have some trouble to process the data correctly.
-Joe
(2,402 Views)
