Will this work to determine the system byte order?
I need to be able to determine, preferably without relying on conditional disable symbols, whether the system on which a VI is run uses big-endian byte order.  What I came up with was to flatten a U32 containing 0xDDCCBBAA to string using the unknown system byte order, and unflatten using a big-endian byte order.  If the pre- and post-flattening U32's are equal, the system must be use big-endian byte order.  Two questions:
1. Will this work?  It recognizes, correctly, that my PC does not use big-endian byte order, but I don't have any big-endian targets to test it out on (see #3).
2. Is there a better way?  Perhaps something already built into LabVIEW?
3. Would somebody with a big-endian target verify that my VI detects it as big-endian?
Mark Moss
(3,019 Views)
How about a simple OS.Name property node?
(3,002 Views)
Take a look at this example
C:\Program Files\National Instruments\LabVIEW xxxx\vi.lib\Utility\sysinfo.llb\Get Current Platform.vi
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,975 Views)
You can simplify your VI a little.  Since you know what the result of the string flattening should be in big endian, just compare the string.
(2,975 Views)
The issue with using the OS Name or Platform is you have to keep track of endian order per platform.  I don't know enough about Macs, but they seem to be able to run as either right now.
I think the test is the simplest, and ultimately the safest, method to find this out.
(2,973 Views)
