Will updating windows 7 to windows 10 affect the current labview 2012 version installed
I have a windows question. In my company we have labview 2012 installed in our pc which is Windows 7. But now we need to update it to Windows 10. Will this have some effect on the current version of labview 2012 installed? Thank you.
Govind.
(1,446 Views)
Most likely.  LabVIEW 2015 SP1 is the first version to officially be supported on Windows 10 (LabVIEW and Microsoft Windows Compatibility).
With that said, I do have older versions of LabVIEW (8.2.1) installed on my Windows 10 machine and it runs fine.  But I only use it in very basic contexts.  You will likely have more issues with drivers than LabVIEW itself.
(1,418 Views)
Govind.
Whenever I see questions like this the first question I have is:
Why do you need to update it to Windows 10?
I am in firmly planted in the "Don't fix something that is not broken." camp. We have a couple systems that still run Windows 7 and one that still runs Windows XP in our lab.
Why? Why not? They still work just fine.
I understand if it's an actual requirement like some government contractors are required to have a certain level of data security implemented and Windows 10 is required to reach that level.
But if it's just your IT department or some manager that wants to upgrade everything for no other reason than to "have the latest version", tell them where to go...
=== Engineer Ambiguously ===
(1,381 Views)
