02-04-2010 12:58 PM
Thanks for the reply. It's always good to have someone who knows the details of what happens inside the code.
intvsteve wrote:Given the original example VI, I was able to activate both the VI and the .NET form ...
I'm not in front of LV at the moment, so I can't check this myself, but I assume that when you say "activate" you mean that the window does grab the focus. That's normal behavior for LV and not what we care about, so I would like to ignore that for now.
What interests me more at the moment is that I did manage to do what we want, albeit sporadically. When I managed to replicate this with my old test VI (which calls Keybd_Event to simulate a key press) it did work as I wanted it - clicking the button in my VI caused the correct letter to appear in the Notepad window. Unfortunately, at the time I didn't think about trying to type in a LabVIEW window. Since you say this allowed you to activate the window, I assume this would actually fail (the keyboard VI would get focus), but it's possible it could work if it was a separate process.
I don't suppose you have any guess as to how I managed to get it to work as we want, right? I'm assuming I'm hitting some corner case in the "non-trivial" window activation code.
02-04-2010 01:54 PM
In peeking at the messages sent to the form, that window does not appear to receive key focus, though it does get activation messages. I can activate the form directly via the 'grouper' button in my taskbar without activating an intermediate LV window. (By activate, I mean 'make the title bar turn blue, and it's the top window in the LV Z-plane' 😉
On the other hand, the LabVIEW VI window does receive key focus events - the Window Manager is imposing this behavior in addition to activation (using SetFocus). Although internally we do have some special kinds of windows for which we do not 'force' key focus, VI windows are not such creatures.
As an aside, using the OS APIs to directly manipulate LV windows is a brittle path to follow, though I have seem some pretty impressive feats accomplished that way. (Often much to my surprise! 🙂 For the benefit of the brave ones out there who attempt this sort of thing, here are some problems that arise in the general case when using the Windows APIs :
09-01-2026 08:53 AM
I eventually found a solution with the help of ChatGPT
Open the project,Run Main.vi,Click OK Button,support 32bit and 64bit
attach zip LV Code and cpp code inside
