Win XP
Hi :
I have dll which was created in dot net , I build application with labview 9 which called this dll using Libraries &Executable ----> call library function
this application works with windows 7 , but I doesn't work with windows XP Bit
just to mention the the dll was complied also under windows 7 and  under 32 bit system in order to support all environments
can any one help me why I doesn't work in windows XP
(3,312 Views)
We can't see the DLL so it's a bit hard to give you ideas. Does it use only .Net functionality or interface to unmanaged DLLs? What .Net version did you target your DLL for? What bitness of OS in both cases? Bitness of installed LabVIEW? Are you sure you have the necessary .Net version and all its dependencies installed on your XP system?
Rolf Kalbermatter  My Blog
(3,301 Views)
Hello rolfk,
I have a similar issue.  To give at least as much info and answers to your questions:
  • Built on a Windows XP SP3, trying to use it on a different machine with the same OS
  • Using Labview 2011
  • Imported using Library Import Wizard (I was the one you replied to earlier today-- found a 'known issue' and worked around: The Import Shared Library wizard does not support macros inside of function declarations. I changed all the macros back into what they stood for.  Also, I added all the headers it said it could not find to a folder and lncluded it the additional folders list, despite the fact that they are .NET predefined headers.  Not sure it is a universal fix so I have not placed it on that thread.)
  • The DLL uses only .Net functionality/no unmanaged DLLs
  • Targeted 3.5 .Net Framework (target computer has 3.5 SP1)
  • Bitness of LabVIEW (I can only assume is 32bit given it is on XP)
  • While none of the .NET developement software is on the target computer, in earlier readings concerning this error they said that re/installing Microsoft Visual C++ Redistributable should fix it.  It did not.
And for completeness the original error was:
"This application has failed to start because MSVCR100D.dll was not found. Re-installing the application my fix this problem."
Thank you for any assistance.
(3,122 Views)
MSVCR100.dll is a Microsoft Visual C++ Redistributable component! However each Visual C version has it's own version, this one is specifically for Visual Studio 2010. So you can't just install any but have to install the right one. There is a chance that MSVCR100.dll is present in your system but somthing is borked up enough that Windows can't load it because it misses other dependencies for that DLL. Rerunning the correct Visual C++ Redistributable installation should fix that. Notice that you might have to install both the 32 bit and 64 bit version on a 64 Bit Windows system.
As to the error messages of the import library wizard, he can't really know what is missing, can he? It's a simple tool that can not know about all the possible software on earth and which of them could be missing, if file xxxyyyzz.h is not found. Besides even if they started such superficial intelligence it would be more often wrong than not.
Macros inside function declaration are indeed a bit "strange". Seems someone tried to outsmart everyone, and potentially himself too.
It does not really matter if the DLL accesses managed or unmanaged interfaces. If the according component is not installed (correctly) on the target system, loading of that DLL fails in either case. The DLL loader is not using any .Net features at all. It is a much lower level Win32 component, which .Net uses too, so it can't really depend on .Net or you would get a so called circular dependency that is almost impossible to manage right.
(3,105 Views)
