Win2000 security and IMAQ vis
I have installed Labview6.1 and IMAQ on WIN2000 and written my own vis for video camera control. I installed the software as an administrator. When I log in as an administrator everything works fine. When I log in as a user the IMAQ vis cannot be found. Why?
(2,857 Views)
It's likely a permissions issue if you have an NTFS system. Either your vi's are in an admin folder made private or a portion of the software is trying to access an admin only folder. You'll have to change the security setings to allow others to use the files.
See:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/d95e17dfa38ca8a386256b21007660d0?OpenDocument
or
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/7f8c8c8c567d160c86256b2000498379?OpenDocument
or do a search on NI.COM for administrator or NTFS
2006 Ultimate LabVIEW G-eek.
(2,857 Views)
Oh yeah, another way around is to just build it as an executable application and put it somewhere convienent, that way you only have to deal with one file.
(2,857 Views)
Thanks Jonni 5. I've gone with the standalone exe as it seemed the simplest.
(2,857 Views)
No sweat.
Glad to be of serevice.
(2,857 Views)
