Window Dragging
In LV6.1 is there any way to prevent window dragging other than making the title bar invisible?
(3,352 Views)
You can disable window move using G Toolbox
George Zou
(3,347 Views)
Hello Jim,
Check out this other Discussion Forum link.  It looks like making the title bar invisible would be the best way to do this unless you were able to determine the Windows system DLL calls that would be needed to do this.
Clint M
(3,316 Views)
