Window Handle
Was searching knowledge base for a method to get a window handle in labview. The only links I found referred to a set of downloadable functions for NI, doc ID#4935 which was dead.
Is there any existing method to get a window handle?
(5,708 Views)
Do a search in the forum with window handle. you can get a couple of solutions.
If still in trouble, post exactly what is your need.
(5,705 Views)
Hi TryingOut,
you can use the functions from the User32.dll, for example these: "FindWindow", "GetForegroundWindow" and "GetDesktopWindow".
Hope it helps.
Mike
Message Edited by MikeS81 on 07-07-2008 08:04 AM
(5,691 Views)
Search these forums for "lvutil32", you ll get the entire library of VIs that deal with the DLLs Mike has specified. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(5,671 Views)
Here are the LLBs in Zip Smiley Happy.
(5,666 Views)
Thanks very much for the responses, these will do the trick.  It gets a bit discouraging for a first timer to try to navigate with the broken links in some of the other threads.
Keith
(5,638 Views)
here are a version saved for LV Version greater than 8.0
(4,930 Views)
