Window Title - LabVIEW 2010 - how to suppress [filename] in title bar
I have seen an example in a textbook of a VI window title that does not have the [filename] appended to the custom text but can't figure out how to do it.
In File - VI properties - Window Appearance there is a check box for Window Title to remove "same as VI" and allow custom text but when I look at the VI window, it still has [filename] appended.
Could someone tell me how to suppress the filename?
(2,637 Views)
Accepted by topic author wildcatherder
The file name is appended when the VI is NOT running,
But when the VI is running only your custom text will be displayed
Omar
(2,627 Views)
Thanks, I NEVER would have figured that out.
(2,623 Views)
