Window10: Labview error when communicate with two FTD2xx
Hi everyone,
I have two usb-ftd2xx to serial convertor, I_MON interrogator which appearing as virtualCom #3, and the other is thorlab Z812 motor stages controlled using kinesis/labview, when only one is connected, let say the interrogator it will work fine, once the thorlabs motor connected I receive the error (picture attached)… So kindly if there is any can help on this
Message 1 of 1
(2,574 Views)
