Windows Firewall Might Be Enabled
Dear, all
the first time i was succeed to install it ,but I can not install the labview after i remove the old version, and every time i got the following things.
i also close all the windows firewall and virus software. it still can not work.
please help me. many thanks.
LabVIEW 2016 English
WARNING: Windows Firewall Might Be Enabled
You have a version of the Windows operating system that enables the Windows Firewall by default. When you first launch LabVIEW, a dialog might appear that gives you the option to receive information over the network. National Instruments recommends you select "Unblock" so that you can use all the networking features in LabVIEW. Refer to ni.com/info and enter the info code expm69 for more information
(4,290 Views)
This is not an error.
It is simply a warning that Windows has a firewall (it didn't always) and that some features may have problems getting thru.
It's NOT telling you that something is wrong.
I would just proceed.  If some parts fail, you will get an error then (I think example finder is one).  When that happens, you have an opportunity to open a hole in the firewall.
But I would leave the firewall intact until you actually have a problem.
Steve Bird
Culverson.com
LinkedIn
(4,253 Views)
Okay, so I paid a ton of money for software not to get answers that 'truly' don't answer the paying user's concern. The code exmp69 IS actually causing the problem, at least by blocking Windows Services from letting us "Start" Ni Device Loader. From within Win Services, the Firewall has been Disabled and so has Defender, but the Win system is still blocking the Start of the Ni Device Loader and thus MAX can't see the 9174 chassis, let alone see the card slots.
To many times throughout the Ni web site, I keep finding short non complete answers to very important questions. Yes, my software is old, but paid over 10k for it, to only use a few times and always be challenged by Windows.
IS there a config file that NI has for us to reset every Windows line item within the Service list, and anywhere else on the system to get the allowable configuration for use?
THx... a bunch of old rocket scientist in a garage loosing it... LOLOLOL Thx
(757 Views)
(753 Views)
I am pretty sure you mean code expm69 instead.
You did not tell us your OS, but LabVIEW 2011 is ancient and not certified for any modern windows OS.
(705 Views)
