Windows Mobile Module - Bluetooth error 2 (Discover devices)
Hi.
I need a little help about the mobile module in Labview.
Im receiving the "erro 2". Im trying make it with a simple code, just the "Bluetooth Discover" function. The error it is the same in the PDA and in the Emulator.
I've did the master reset in the PDA but does'nt work.
Could someone help me in this trouble?
Bruno.
(3,269 Views)
Hey Bruno!
What message does the error 2 shows? give me more details
Can your PDA be discovered by a device other than a PC running LabVIEW?
Just by curiosity, why are you using this PDA module? It is pretty old. Tell me what you want to do and I might find and alternative that works for you.
Best Regards.
Felipe Flores
Technical Support Engineer
(3,184 Views)
