Windows Screen Saver and Monitor Status
How do I communicate to windows to find the Windows screen saver status and the monitor status?
Tim
GHSP
(3,061 Views)
I don't know the particular API calls you need for that, but here's the general way to access Windows innards:
Use the CALL LIBRARY function, and point it to ADVAPI32.dll.
This particular call is set up to call "GetUserNameA", returning the logged-in user's name.
If there's an API for what you need, then configure this function to go call it.
Steve Bird
Culverson.com
LinkedIn
(3,048 Views)
Thank you for that information. I had suspected as much and was hoping for a little more help with the actual direction that I might need to go.
Tim
GHSP
(3,035 Views)
