Windows "Blue screen of Death" when booting computer attached to LabVIEW PXI realtime system
Good Morning (at least in the western hemisphere)!
     I'm having a problem on two test systems where intermittently, at least on one machine, I get a Windows "Blue Screen of Death" error message when booting the machine connected to a PXI RT system. I reloaded the RT systems software yesterday (LV RT 7.1.1, NI-VISA 3.3.1) and am having this problem on two different setups, two laptops, two PXI chassis. Our short term work around has been to boot with the network cable removed at one end or the other, but these are the baseline models for a larger test system in the design/construction stage that will not be used by knowledgeable engineers but by (probably more knowledgeable!) technicians.  Any ideas would be a help
Thanks again,
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,468 Views)
Blue screens are almost always caused by drivers and not by applications, so chances are there's a problem on the driver level.  The crash log file will be instrumental to diagnosing this problem.
Turn on the crash event logging as described in this Microsoft KB:
http://support.microsoft.com/kb/314084/EN-US/
...and then post the details from the crash found in the Windows Event Viewer here. That will help us narrow the problem down.
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(2,449 Views)
