Windows server 2008 R2 installation NI-VISA error
I am having a problem installing Labview 8.6.1 for FIRST robotics (2011) on Windows Server 2008 R2.
I get 4 errors when installing NI-VISA, and they relate to 64 bit:
error 1722
* for 64 Bit Windows
and the * is:
NI-DIM
NI-MDBG
NI-MXDF
NI-ORB
I have found one older unresolved thread with the same problems, but it is not resolved of course. I think labview still works, but I do not want any problems when we deploy our code.
(3,430 Views)
Hi Mark,
Take a look at the following KB here
Also you might want to post the FIRST forums at www.ni.com/FIRST or www.ni.com/frc
Joe Daily
may the G be with you ....
(3,406 Views)
Hi Joe or Mark,
Were either of you able to reslove this issue?
im running into a similar problem.
-Frank
(3,256 Views)
