Windows services
How programmaticlly get status of "A" Windows service?
Using "System Exec VI" was referred as a way to start/stop a service with proper command line text.
Is this VI the only solution? if yes, some detail how to ?
or any alternative?
David
(3,538 Views)
Accepted by topic author David1980
You can do it with .net
The example here lists all the services and its status. You can refer to msdn documentation for more details.
http://msdn.microsoft.com/en-us/library/system.serviceprocess.servicecontroller.status(v=vs.110).asp...
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,530 Views)
sc query servicename
Output example:
NOME_DO_SERVI€O: fax
TIPO : 10 WIN32_OWN_PROCESS
ESTADO : 1 STOPPED
CàDIGO_DE_SAÖDA_DO_WIN32 : 0 (0x0)
CàDIGO_DE_SAÖDA_DO_SERVI€O : 0 (0x0)
PONTO_DE_VERIFICAۂO : 0x0
AGUARDAR_DICA : 0x0
(3,518 Views)
