Wire "Hidden" behind structure in LabVIEW 2014
Used to be semi-transparent, now becomes totally transparent.  Anyone see this:
George Zou
Message 1 of 24
(5,163 Views)
I haven't got 2014 to try it but is the wire inside the case structure not connected to the case selector and the error out terminal but you just can't see the vertical wires because they're outside of the bounds of the case structure?
The branch of the error in goes behind to the sequence structure.
I want to see you triple click on some wires to be sure Smiley Very Happy
(If this isn't a trickery of the wires then it's a feature of LV2014 I didn't know about!)
(blog)
Message 2 of 24
(5,152 Views)
No the VI is made for the post.
I wired it right before the post.
Here is another one:
George Zou
Message 3 of 24
(5,143 Views)
LabVIEW Pro. version: 14.0f1 32 bit on Win7 64 bit.
George Zou
Message 4 of 24
(5,141 Views)
I didn't PS the image.
Here is the test VI.
If it's opaque, add this to your .ini file:
structuresFadeToDiagramBeneath=TRUE
George Zou
Message 5 of 24
(5,127 Views)
Is your post just an observation you've noticed and you wanted to share?
(Edit: Yes, apparently so!)
(blog)
Message 6 of 24
(5,126 Views)
I wonder if there is another secret .ini setting that I don't know of, which can fix the problem ?
George Zou
Message 7 of 24
(5,122 Views)
George,
You may want to create a VI in LV 2013 and the same one in 2014 and show the difference. Also, note that you have a special INI key set to enable this setting of semi transparent. Most users don't know that exists.
Message 8 of 24
(5,095 Views)
Here is how it looks like in LabVIEW 2013:
George Zou
Message 9 of 24
(5,082 Views)
Why would you be trying to hide wires behind strucures in the first place?
Message 10 of 24
(5,066 Views)
