Wireless Compact RIO Data Transfer
I need to configure a remote wireless automotive environment data acquisition device to monitor voltage, temperature, and accelerometers. A Compact RIO system looks like it would satisfy the the DAQ requirements.
What would be the cleanest way to enable wireless transmission of data to a web site or computer while the vehicle is out driving around. The wireless device would need to be powered by automotive DC power.
(3,497 Views)
This sounds like a very interesting application! You should definitely be able to wirelessly send and receive data from an in-vehicle cRIO, but there may be a bit of programming involved depending on the communication method.
The simplest way to communicate would be over wireless ethernet, provided that you have wireless network coverage during your data acquisition. Since the cRIO is specifically designed to communicate back to a host over ethernet, this should be the least amount of work on your part.
I would encourage you to browse the forums (ni.com/forums) for other communication ideas as well. We have had customers write applications that communicate through cell phones, radio, etc as well. Using one of these communication methods should be possible, but may require more work on your part to send device-specific commands in order to transfer your data.
The cRIO can definitely be powered off of a DC source. You will require a DC supply between 11-30V (refer to your specific cRIO controller specifications to double check). Power consumption will vary depending on your controller and modules in the cRIO chassis.
Would you like me to have someone give you a call and provide more information about our cRIO systems and the various I/O modules that you can use?
I hope this helps!
Casey Weltzin
(3,474 Views)
You might also check out the Wireless Lan Module S.E.A makes for the CompactRIO platform.
Steve
(3,471 Views)
Steve + Casey -
Thanks for the responses. I did run across SEA for CRIO wireless modules and I think that will be the way to go. The data acquisition will have to be in a vehicle as it is driving down the road with no operator intervention. My intent would be to go with the GSM transfer.
Thanks again
Dave
(3,461 Views)
