Wireless Vibration Monitoring
HI, i need help with a labview program, i need to receive data from a sensor (QM42VT1) connected to a wireless controller "DXM 700" (datasheet: https://info.bannerengineering.com/cs/groups/public/documents/literature/207893.pdf?fbclid=IwAR0v26x...).
The controller has two ports that I can see, in its datasheet the first is to connect via modbus with another controller, and the second is by radio signal according to the frequency, that's why it has those antennas..
basically that's the connectionbasically that's the connection
I understood that's the conecction.
the only thing I need is to receive data from that sensor..
i want to know, how i could acquire sensor data from labview?
I appreciate any help, thank you very much!!
(1,747 Views)
First, you need to define what communication interface you would be using to connect your controller to a PC running Labview.
(1,658 Views)
