Wiring String Potentiometers with different power supplies to NI9207
I have an issue with wiring a number of sensors which require independent power supplies to a single 9207 card (I have 2 cards in total) and CompactDAQ combo. I have 12 sting pots (ASM POSIWIRE WS31-500-R1K), 1 inclinometer (Cline Labs Electronic Clinometer), 2 pressure transducers (ESI GS4200-0050AB), 4 load cells (RDP Amplifier Type S7DC).
The issue seems to be around requiring a single common throughout whilst require 24V and 10V supplies.
I am seeing ghosting of the an activated string pot on the other string pot signals.
Could anyone suggest an appropriate solution?
(2,719 Views)
Hi Kevlewins,
Could you please elaborate on the issue you are about your GND?
Have a look at the following and see if it might help:
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
In regards to your ghosting issue, please have a look at the following:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHy6CAG&l=en-US
Kind regards,
Natan Biesmans
(2,664 Views)
