Wiring diagram keeps popping up during execution
An easy newbie question for you die-hards out there...
I have a program that upon execution, forces the wiring window to the
forefront and pauses over a certain area of code. There is apparently
nothing wrong with this part of the code (a simple case structure), as I
can click to unpause or step over with no error messages whenever the
program gets to this point. This hold-up is annoying because it halts
up the rest of the program and I don't see the point of it.
My question is wheter or not it is possible to force the program not to
pause and ask me for redundant stepping requests. Conversely, is it
possible to force pauses at particular points in the program? Might
have done it uninentionally...
Th
anks
Sent via Deja.com
http://www.deja.com/
Message 1 of 10
(3,867 Views)
You've probbably placed a breakpoint somewhere. This can be seen in the
diagram as a small red dot. If you cannot find it, use "project" from the
menu, "Find", select the object "Breakpoint" in "Other".
Wiebe Walstra.
Note: To place them, make the tools palate visible, select the red dot, with
arrow, and put it in the diagram.
AIR technical Automation
www.air.nl
wrote in message news:95e40d$l83$1@nnrp1.deja.com...
Sent via Deja.com
Message 2 of 10
(3,867 Views)
Thanks for the suggestion.
Checked for break points and there were none. Came up with neither the
red dot nor a positive on the deliberate search. Now I know how to
check for breaks in the future though...:)
Cheers
In article <981116177.21044.0.pluto.d4ee054f@news.demon.nl>,
"AIR Tech. Autom." wrote:
> Hi,
the
the
> Regards,
> Wiebe Walstra.
dot, with
> www.air.nl
> eja.com> wrote in message
I
to
> Thanks
> Sent via Deja.com
Sent via Deja.com
Message 3 of 10
(3,867 Views)
Make sure that you don't have Execution Highlighting selected. That's
the light bulb on the menu bar of the wiring diagram.
Stephen
ken_eric@my-deja.com wrote:
> Hi,
> Cheers
> > Hi,
> the
> the
ther".
> > Regards,
> > Wiebe Walstra.
> dot, with
> > www.air.nl
> > wrote in message
> I
> to
> > Thanks
> > Sent via Deja.com
> Sent via Deja.com
Message 4 of 10
(3,867 Views)
Heh heh heh. No, it wasn't that either. 🙂
Happens only if a particular case occurs. When the other case occurs,
the program doesn't even stop.
Cheers!
In article <3A7ACD41.30434FA1@swri.org>,
> Regards,
> Stephen
Sent via Deja.com
Message 5 of 10
(3,867 Views)
I had about the same thing happen a while back on some code. It about drove
me nuts.
It turned out that there was a breakpoint but it was hidden. Unfortunately,
it didn't show itself until I started deleting portions of my code. When I
deleted a string control, all of a sudden a breakpoint appeared on the
broken wire where there was none before. I removed the breakpoint,
reassembled the code, and it worked fine. I would use the execution
highlighting to watch exactly where the breakpoint is triggered, and then
maybe delete small sections to see if the same thing happens. I know this
isn't a great solution, but it worked for me. Maybe it will work for you
(no guarantees).
Make sure you can re-create the code though, print it out
, back it up, I
don't want to be held responsible if you can't get it back to proper working
order.
Spencer
wrote in message news:95entl$6aj$1@nnrp1.deja.com...
> Cheers!
> > Regards,
> > Stephen
> Sent via Deja.com
Message 6 of 10
(3,867 Views)
On Fri, 02 Feb 2001 14:11:03 GMT, ken_eric@my-deja.com wrote:
>Hi,
You could also check out for a red frame on the inside of a case,
while, sequence or for loop. It indicates a brekpint set on that
frame.
Regards
Rolf
>> Hi,
>the
>the
nt" in "Other".
>> Regards,
>> Wiebe Walstra.
>dot, with
>> www.air.nl
>> wrote in message
>I
>to
Message 10 of 10
(3,866 Views)
For the sake of posterity, here's how I got around the problem:
By clicking on the icon of the VI, choosing window options and disabling
the "allow debugging" option, I basically told the VI to stop bugging
me. There might be a minor nonideality in my code, but since it's
nothing to stop the program from doing what I want it to do (works when
I step through it manually anyway -- what more would I want to show me
it works?) I'm leaving it at that.
An old-hat trick to the pros, but at least now I know...
Thanks to all who helped.
In article <95e40d$l83$1@nnrp1.deja.com>,
I
to
> Thanks
> Sent via Deja.com
Sent via Deja.com
Message 7 of 10
(3,867 Views)
It is also possible to have accidentally set a breakpoint in a location that
is currently not being displayed, maybe on a wire that is under the border
of a case or loop. Try doing a project search for breakpoints.
- Vinny Recca
> I
> to
> > Thanks
> > Sent via Deja.com
> Sent via Deja.com
> http://w
ww.deja.com/
Message 8 of 10
(3,867 Views)
Baybe a little late, but it could be the "Suspend When Called" option. The
VI will popup when called, and the run button will be changed in a arrow up,
with a line under it.
Wiebe Walstra.
www.air.nl
wrote in message news:95rkn4$cbk$1@nnrp1.deja.com...
at that.
I
to
> Thanks
> Sent via Deja.com
Sent via Deja.com
http://www.de
ja.com/
Message 9 of 10
(3,864 Views)
