With Modbus LabVIEW Library, why do I need the DSC module?
Hello all!
Modbus LabVIEW Library is enough to make a communication between CRio and other device or do I need also the DSC module?
Thanks in advance,
Best regards
(4,293 Views)
No, you only need the DSC module when you want to use DSC module functions.
André (CLA, CLED)
(4,292 Views)
Hi!!! Thanks for your fast reply!
But what kind of functions for Modbus can i find in DSC?
Regards
(4,285 Views)
None.
You can use the DSC module to interface a modbus OPC server that scans your modbus devices.
André (CLA, CLED)
(4,277 Views)
Thanks once more 🙂
Do you know if the Modbus Library works in PDU or ADU?
Regards
(4,255 Views)
 I would say ADU, since its incorperating addressing and error checking. PDU seems only usefull with only one connected device.
André (CLA, CLED)
(4,253 Views)
It somewhat depends on how much data you want to read and how fast it needs to update. Modbus commands are good for reading 100-125 words of data in one command.
(4,240 Views)
