With a Gage A/D board cs82g need a prf of 480hz and data range of 10k-30k of data can this be done? need example code.
Using 6.1 and a Gage Board CS82G
(2,520 Views)
The model you have has a 2GS/s sampling rate and a minimum of 2M sample memory so I don't think 480 hz is going to much of a challenge. I use a lower end model for a higher frequency though much fewer samples and it works fine for me. The best thing to do if you have any questions, is to contact Gage directly. I've found that they're very helpful. They can also provide a LabVIEW SDK. Mine is pretty old - it dates to before their buyout by Tektronix and the subsequent sale from Tek to Kinetic Systems so you should really contact them for current pricing.
(2,520 Views)
The Problem is that I have to take anywhere from 100 to 2000 data points with 3-10k of data per point would out run the on board memory. I have to dump the data off the board before the next PRF. I have the new Labview SDK. Still working on it. We are using an external trig to start the data string.
(2,520 Views)
