With my pda and the 6024 DAQ I am measuring only negative voltages
I am using LV 7.1 PDA and a 6024 PCMCIA DAQ Card. Measuring works fine but all positive voltages are cut off. In the configuration utility I put the settings on bipolar, RSE. What's wrong?
Michael
(3,529 Views)
Hi Michael,
which DAQmxBase driver are you using? I attached a link to the DAQmxBase driver 1.5. This is the latest driver which supports LV PDA 7.1
http://forums.ni.com/ni/board/message?board.id=170&message.id=211286
Can You test the PCMCIA card in a laptop to verify if the card is working properly. You set the card to bipolar. Which input range did you set?
Mayby it is set to a negative range.
Klaus Dinnes
(3,472 Views)
