Wma Pro SPDIF Pass Through......
Hi friends,
In my application i need to give WMAPro and DTS streams as input to the DVD Player from the system......using a sound card which is connected to system....
I have heard that using SPDIF Pass through in windows we can pump DTS or WMAPro streams...
How to do it..in LabVIEW....?
SODLB
(2,750 Views)
I am not sure of the acronyms that you are using.  If you could clarify your setup and your ultimate goal, hopefully I could help you out with your application.
Nadim
Applications Engineering
(2,736 Views)
