Wnen Using Systemexec.vi pb with path on XP
When I want to launch a batchfile with System exec.vi with the batchfile somewhere else than in the working folder of my VI, it doesn't work. The only solution is to put my batchfile in the working folder without path given as parameter. Have you a solution?
(2,711 Views)
If the path has spaces in it, you must use quotes, like "C:\temp
directory\batchfile.bat".
Perhaps that's the problem...
Wiebe.
"raymond_73" wrote in message
news:50650000000800000055A50000-1042324653000@exchange.ni.com...
(2,711 Views)
