Word Bookmark values to SQL
I have created template.doc using bookmarks and pushing the data to microsoft word doc.
Is there a way to read
the report.doc and extract the bookmark values to LabVIEW?
Is that possible?
Are there any examples I can look at?
Thank you
(662 Views)
You should be able to use the ActiveX property _Document.Bookmarks(i).Range.Text to get the bookmark contents of an open document.
I usually open Word automation while using the Report Generation Toolkit (Word Specific -> Word Advanced -> Word Get ActiveX References). If you need to open the document manually there should be Activex routines for that as well.
(634 Views)
