Word Insert Field
In the Report Generation option , I want to include some text inbetween a report. I have created bookmarks for these. After that can i use Word Insert Field block to update these text in the report. But it is not updating in the report. Any body knows how to add text not in the end of report, in between against bookmark ?
(2,941 Views)
Bose,
I'm not sure I fully understand your question but it sounds like you are trying to add text to a bookmark with the Word Insert Field.vi, but the text is instead inserted at the end of the document. The Word Insert Field.vi only inserts the text at the end of the document if no bookmark is specified in the bookmark input of the VI. Make sure that you are specifying the correct bookmark at this input in order to add text there.
If I've misunderstood your question, feel free to ask again, but try to clearly explain what you are trying to do, how you've tried to do it so far, and how those attempts have failed.
E. Sulzer
(2,919 Views)
