Word report generation VIs are not found.
I've installed LabVIEW 6.1 followed by installing Report Generatio Tool set, but I don't find word specific VIs and excel specific VIs on Function Palatte. Could u plz. let me know what I m missing there.
Regards
GNS
(2,670 Views)
GNS,
Which version of the toolkit did you install?
Do you see the Report Generation Toolkit listed under the Add/Remove Programs in control panel?
If you have multiple versions of LabVIEW, check in which folder did the toolkit get installed.
Can you find word and excel llbs under ...\LabVIEW 6.1\vi.lib\addons\_office directory?
If these VIs didn't get installed, you should check the version (LabVIEW 6.1 needs toolkit version 1.0.1) and reinstall the toolkit.
If you do have these llbs, try to manually edit the palettes and add new subpalettes linked to these menu files:
LabVIEW 6.1\menus\default\excel.mnu and
LabVIEW 6.1\menus\default\word.mnu
Check out the following KnowledgeBases as well
"Palettes Not Populating" Error with the Report Generation Toolkit 1.0 for Microsoft Office and LabV...
Installing the Report Generation Toolkit on Multiple Versions of LabVIEW
Zvezdana S.
(2,670 Views)
