Word report with ActiveX
I would like to generate a report in Word via ActiveX. I found an
example on NI's site that should make it fairly easy. However, I
noticed that some of Word's ActiveX methods parameters have changed
between whichever version the example was written with and Word 2000.
(With Word97, the example runs fine, so it may have been written for
that version. If Word 2000 is on the machine, you need to reset the
method nodes the refresh the parameters list.) My problem is that the
target machine will be using Word 7a, installed on a server not on the
local machine. So I have two questions:
Does anyone know how stable the ActiveX interface was between Word 7a
and Word 97?
When Word is installed on a server enterprise-wide, and th
e computer
starts it up over the network, will the ActiveX components be registered
on the local computer?
Thanks in advance,
Dave Thomson
David Thomson Original Code Consulting
National Instrument Alliance Program Member
www.originalcode.com
dthomson@originalcode.com 303-499-1973 (voice and fax)
Message 1 of 1
(2,789 Views)
